SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Wed Apr 27, 2005 11:28 am
Theres a connector down by the passenger side where the ECU will sit, that can be connected if you make sure to repin one of the connectors to match the colors. Sometimes this connector will be different from the US one so you just need to hardwire them in.
Up by the batter there are 2 connectors, just cut the wires you need to to make the diagrams on ht's site, heres their old diagram if you havent seen it.
If you want the transmission sensors to work other than the speed sensor (which plugs in) then you need to splice the wires or use one of the sets of connectors, matching color to color. There are like 2 or 3 connectors down there.
You need to extend the O2 wiring, and MAFS wiring. You can do the power steering wiring and boost solenoid wiring if you want to but its not needed. The O2 should be something like a foot give or take. The MAFS depending on where it was cut should have about 3 to 4 feet since it needs to stretch across the front of the car or at least over the front of the engine. The PS and boost solenoid need between 4 and 5 feet, you can do them later.
Make sure to use the proper gauge of wire for your MAFS and properly shielded wire is a plus.
