silaytee wrote:planning to pick up a 240 89-94 soon and do the swap instead of sticking with a ka. before starting and following through with that plan i would just like to know of the pros and cons of each motor.
I recomend you get an s13 motor...wiring up is a breeze compared to the s14 in an s13 chasis.If you are worried about the health of the motor, i recomend you getting a blacktop s13. they were in 97 and up 180sx(rps13) much newer motors... rather the redtops range from 91-96 rps13 chasis (liftback model) or 91-94 in the ps13 chasis (coupe model).
if you are going to buy a motor...try to get the front clip. You get everything (ecu, harness, ignitor, smic, afm, maybe lights)if not, make sure you get everything, otherwise it will be a pain later.
good luck to you :ylsuper ~Joe~
http://www.camp1320.com --
