S13 sr swap into s14 running poorly/rich
Cerevo
Car: 97 240 base
Alright, first off I have a wiring specialties harness so I assume all wiring is good to go. all connections are secured well.
Got the car running a couple days ago but it was stumbling and dying easily and I could barely get into boost it's missing out so bad.
I have a Greddy knockoff intake manifold and the teflon gasket that came with it was leaking, as there was fuel on top of the gasket.
Replaced that with the stock IM gasket, no more fuel leaking there, assume its good to go.
The car is still missing at idle really bad, I've checked everything for leaks with soapy water and can't find anything. I can rev it up to about 5500-6k if I barely push the throttle down a little as I go but then it starts breaking up and missing.
Driving it pulls pretty well with little to no miss from 2k rpms to about 3300 and then it breaks up bad up to around 4k and it just refuses to go any higher no matter how much or little throttle.
I've changed MAFs with a known good one, I changed the coils with no effect, I've gapped my plugs to .027"-.028", if I unplug the MAF it idles the same but wont rev over the 2500 limit... When I first cold started it this morning I unplugged the coolant temp sensor and it seemed to run a little better until it warmed up and then it died and wouldnt start again until I plugged it back in.
Also I set my CAS exactly how the FSM says to, lined the right most dot up, slid the CAS in and then it lined up with the left most dot perfectly.
I pulled my plugs out and replaced them with the ones that came in the engine and nothing changed, though my plugs were really black so I cleaned them off before putting them back in (when I gapped them) with no change.
I can't think of anything else right now that I've tried but since Saturday I've done nothing but search and troubleshoot with no increase in performance to speak of. Can anyone help me!?
Cerevo
Car: 97 240 base
I did find today that I have a different FPR on the fuel rail I was using so I put what I know is a stock one on and changed every injector I was able to hit a little over 2.5 pounds of boost but then around 3500 it started breaking up, and at 4000 rpms it sputters really bad and wont go any further
Cerevo
Car: 97 240 base
Compression numbers
170 165 50 155
One of these things is not like the others... Hopefully its in the head though oil made it have 120...
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Possible leaking head gasket? 3rd reading from the others not looking good though.
Morph
Car: 91 Sr Powered Coupe
HG probally, but i thought that if it came up after adding oil piston rings were s*** too?
Cerevo
Car: 97 240 base
I did a leak down test, came out the block. The rings have to not be sealing so I'm pulling the engine
