pearlS13 wrote:Hey guys, my SR will throw a flame once and a while if i rev it pretty hard and also between shifts sometimes if im beating on it. Im running a 3inch turbo back exhaust with a 3 inch test pipe, greddy fmic, t25 at 14psi, and safc-2.It usually happens when i get a back fire at high revs. Is this type of thing normal when running a test pipe or is something wrong? I havent yet had it tuned on the dyno so it may also be running overly rich.
with your Greddy FMIC....did you mount your BOV down below by the inlet piping to the intercooler or is your BOV up top in your engine bay on your hotpipe?? and if you did mount it up top in the engine bay...what did you do to block off the hole in the inlet piping?? (Greddy conveniently designs their FMIC for use w/the factory BOV...which requires an underneath mounting position)
