Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Jul 31, 2007 8:30 am
It technically can, but I believe you get more blowby when you do it though. The can's purpose in life is to act as a sort of collector as intake gasses blow oil fumes in the direction of the can.
S14s get away with no catch can because their oil return line is not directly connected with the intake hose. If you remove it, I would suggest removing the intake line and attaching a small filter to it.
