So i'm just trying to star my sr, the engine crank, the fuel pump work, but got no spark and ingector pulse... The ecu send me a code 11 ( CAS) when i try to start the engine... but i chek the my wiring many times and chek the CAS as its tell in the FSM and every things ok i've also try another CAS and same thing. ground is good.
i'm wondering if there are relays for the ignion and injection??
Or can it be a bad ECU??
Any help will be apreciate
