S13 SR into S14
NISSANRACER
I should really be able to figure this out but I have a few questions for those out there with swaps of S13 Blacktops into S14 chassis... Does anyone have a pinout of power plug F3 or the two power plugs by the battery and what they are supposed to wire to on the SR harness? I have completed harnesses from both cars (front clip S13) so I have all of the correct SR plugs supposedly but all the info I can find shows a brown power plug out by the battery, I do not have that and no F3 plug or power plug pinouts are in the S14 FSM??? Any help is greatly appreciated.
SpeedRacer1
Car: 1990 240SX, G35
Have you checked here?http://sr20.hybrids.jp/install....html
Not sure if that helps.
NISSANRACER
Thanks, I have already visited his site, most of his information is correct especially for the windshield washer wiring and fuel pump relay, however I think 95 and 96 power source wiring is a little different or something as well as red top power harnesses and blacktop power harnesses even though they are both from a S13 Chassis...? Can't seem to determine what goes to the instrument cluster either? Is everyone just making a new harness right off of the ECM outputs or are people tapping into the Stock harnesses of their KA S14? Thanks for any help...
