SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Feb 28, 2006 5:41 pm
Although the connectors of the S13 and S14 speed sensors look different, the gears will slip right into the transmission. If it does not fit or will not go in all the way its either not the right speed sensor ie wrong car, or the speed sensor for an automatic, which will not fit a manual transmission.
Also when you switch the speed sensors between S13's and S14's you need to cut off and splice in the plug for the corresponding speed sensor.
