danstachet »
https://forums.nicoclub.com/danstachet-u48678.html
Sun Jul 15, 2007 6:24 am
Ok, here's how it all started. I had an 89 hatch that i swapped an sr into and everything worked fine, no problems at all. i did the wiring myself and had no problems what so ever. Now, i've purchased a 90 coupe that was an automatic to begin with and swapped everything over into it. I plugged everything in, and the car fired up. The only problem is none of my gauges work. gas gauge, temp gauge, tach or speedo. None of the warning lights light up when i put the key in the on position either. The cluster doesnt even light up when i turn the headlights on. The only thing that works on the cluster is the clock. I've also borrowed a cluster out of a working car and it didnt help. If anybody has any insight into what could be causing the problem please help!! And i have tried the search button and found nothing even remotely like this. thanks in advance.
Dan
UPDATE: I just found out (now that its dark out) that the gauges do illuminate, but i also found out that the blower motor isnt working. Ive checked every fuse in the car, and found NOTHING wrong with any of them. i also noticed that the automatic seatbelts arent working
Modified by danstachet at 8:22 PM 7/15/2007
Modified by danstachet at 11:37 PM 7/15/2007
