Its been quite some time since I have been on here...
Basically I have spent the last 4 years building my car and this is the only thing left to be done/fixed.
Here is what it is doing:
http://youtu.be/R4NyBT0pnYM
Basically it seems to be running insanely rich so you have to ease on the throttle. Also, as soon as you even out boost/vacuum at 0 i think it is cutting spark or just dumping too much fuel because it boggs then backfires when you let off the throttle.
It has a new water temp sensor, i have checked/swapped ignitor and coils, Boost tested ok multiple times, checked for vacuum leaks, Checked my timing a few times...and here i am
Any ideas?? Thanks!
