s13 speed cut help?
sly240
Car: 93 240sx
Ok so I have been SERCHING but I guess I suck at it because I can’t find what I’m looking and I’m sure it has been covered.
So I’m trying to remove my Governor. I have a 93 240sx with a red top sr20det. My speed tops out at a little over 110MPH. I have seen the greddy speed cut device has anyone used one? How did it work? Any other ways to cut the speed limiter? Thanks.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
You can try one of two things...disconnect 4th and 5th gear sensors that should work. If that doesn't take care of it than cut the speed signal input wire at the ecu. The only thing is if you have a chipped ecu with launch control DO NOT cut that wire because than the car would redline at your programmed launch rpm. Plus usually if an ecu is chipped than governor is deleted from the program.
compactfean
daily
Btw, to clear things up cutting the speed input at the ecu WILL NOT affect speedometer. The speedometer receives signal from speed sensor, uses the signal and also converts it to a signal the ecu can use and ecu uses converted signal from cluster.
sly240
Car: 93 240sx
I have heard that this will create problems with the car running right. Anyone ever heard of this happening?
compactfean
daily
My car ran fine without it....it doesn't affect our cars because we are not speed density tuned like Honda's are. We are maf/tps tuned so it only effects redline/governor.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Use an automatic ECU and your done
sly240
Car: 93 240sx
Does that work with SR and do you know about how much one goes for? Thanks.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Ahh i misread that thinking KA24DE being 111MPH. Hmm I have no clue, maybe this is better asked in SR
compactfean
daily
OutToWinPAHC wrote:Use an automatic ECU and your done
With the side affect of high idle.
sly240
Car: 93 240sx
how high of an idle are we talkig?
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Maybe a 200rpm difference, just adjust it, plus you'll be running a 5spd TPS (different design but unsure if there is any technical/functional difference)
