blkvrtswp »
https://forums.nicoclub.com/blkvrtswp-u185208.html
Sun Sep 02, 2012 8:07 am
You can use a gallon paint can and bend it around the can to get a 180 degree bend. the loop ends up right under the alternator / sway bar / oil pan, messy and in the way but it is do-able with $0.
You can cut it and remove the big loop if you want. I had mine brazed together for $12 at a hydraulic line shop (snow plow shop for those in the snow belt!). It held for 5 years until I sold the car, probably still working.
Good luck with your swap!
