ag240 »
https://forums.nicoclub.com/ag240-u93759.html
Sun Jan 03, 2010 4:44 pm
I searched and searched, found alot of conflicting information.
info: 93 hatch, kade, 130k, hi-flow fuel pump, Adjustable fpr, new cap, new rotor, new wires, new plugs(possibly fouled), changed coolant, and always put in 91 octane.
I went to get a pretest at the test only center, they said HC levels were too high.
What can i do to lower the HC levels?
I read that you can put rubbing alcohol into the tankand it will reduce it, but raise NOx.
Could it be low spark? bad o2? bad cat? fuel pressure too high or low? need to change my oil? any suggestions can help as im due for smog ASAP.
Thanks!!!
