S13 Smog check help 2009
supra33202
I have a 1993 S13 Hatchback with 257K miles.
My result:
Test 15MPHHC: MAX 88 AVE 21 MEAS 113CO(%): MAX 0.52 AVE 0.06 MEAS 0.35NO(PPM): MAX 704 AVE 150 MEAS 929
Test 25MPHHC: MAX 53 AVE 13 MEAS 63CO(%): MAX 0.50 AVE 0.05 MEAS 0.18NO(PPM): MAX 738 AVE 136 MEAS 322
I failed NO in 15mph test and HC in both 15mph & 25mph tests.
Here is my result from last year:http://nico.zeroforum.com/zerothread?id=328637
What I did before the smog test:
1) oil change2) Retard ignition timing to 15 BTDC.3) With under a 1/4 of gas, I poured in 2 gallons of denatured alcohol.
When retarding timing, I tried to adjust the idle screw to 650 rpm with TPS sensor disconnected. However, I turned the idle screw to clockwise max. My digital timing light still says it is about 760rpm. The idle was rough and sometime stalled my car. So I turned counter-clockwise a little. The idle rpm is about 800 rpm. Then, I rotated my distributor counter-clockwise to retard my timing to about 15 BTDC. My idle was still fluctuate sometimes (500rpm then to about 700-800rpm for about 2 seconds).
Did I do this correctly? Please advise.
The EGR valve is working, but I didn't take it out and clean it. The cat looks like of old. I didn't do anything with the cat.
Reference:
zerothread/254123http://forums.nicoclub ... ead/358264
supra33202
I forgot to mention that I also failed:
Ignition timing: 15 BTDCFuel Cap Functional
For ignition timing, I adjusted it to 20 BTDC already. How about fuel cap functional? Do I just need to buy a new gas cap?
Thanks!
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
replace gas cap,it looks like your egrs working, cuz your nox is down on cruse. hows your plugs? i hate to say it but your best bet may be the cat.check your cooling system, does it run ok or does it run a lil hotter?
