S13 Silvia steering wheel install?
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
NoDrifto
i got an old s13 wheel trying to put it in mine.....i figured how to get the wheel off but its just stuck.....anyone got some advice to pull it out? i did a swap on my suibaru and it came off, a lil work but it came off.....this nissan is being very stubborn......i see two holes on either side of the center, maybe two bolts to screw and help pop off? anyone know the size?
lonelywanderer
Car: 91 240sx coupe
i was able to whack the backside of the wheel and get mine off with a little patience.... if not steering wheel puller
NoDrifto
i may wd40 it over nigth and then try with the rubber pallet tomorrow =P so i guess there no real trick just very stubborn
NoDrifto
i tried to hit it off again and no luck....a buddy had a custom made steering wheel puller so i used that and it popped right off, took three times to get that sucker straight eheheheh
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I used a steering wheel puller to get mine off you can use one for free at pep boys. they have a loan a tool program.
240DRFT
does pep boys loan out a lot of tools for free? i thought schucks did too...apparently not, and not at a low cost either.
so this is how u should get a wheel off? then would a hub just fit on there after...might be getting a hub/detachable wheel
sean8564
1993 Nissan Silvia
pep boys here was free
manasol
You know I had to pull my alarm so I decided to pull the steering wheel to make thigs easier.I just straightened out the wheel, tugged, and it didn't come out. So I Pulled at hard tugs with a little upwards force.
EDit: It was just one k/nut in the center.
lonelywanderer
Car: 91 240sx coupe
240DRFT wrote:does pep boys loan out a lot of tools for free? i thought schucks did too...apparently not, and not at a low cost either.
i just pulled off the stock wheel and slid on my wheel and hub and tightened the nut down.... just make shure its all straight first.
Return to “Interiors”
