s13 silvia front end.. having problems shutting hood.
accordscantdrift
When I shut my hood it looks like **** on my car. Does it sound like I need more body work or is it because I have a ka24de in there instead of an sr? Im wondering if its hitting the hood or what..
drifts14x
Car: Cars, Motorcycles, Drifting
If you think the hood is hitting the engine, try it out and make sure by putting something wet, like a paper towel on top of the engine cold, close the hood, re open it, and check for water on the hood. If this is not the case, maybe you need a spacer of some sort to better angle the hood.
electricproblem
i had the same problem i had to trim up my hood latch a little bit
