Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Fri Sep 24, 2004 4:22 am
Ok, first of all, if you're rollin on stock struts, they're blown. This will contribute to your problems but it's definitely not the only thing wrong. You can look into replacement struts or just get a coilover kit. There are hundreds of options here. To find out which one is best, tell us what you plan on doing with your car and how thick your wallet is. That floaty feeling in the rear should go away once you replace your struts.
Second, all your ball joints and bushings are blown (again, if they're all OEM). This will also contribute to your problems. The first part you should replace IMHO should be your tension rods followed by tie rods (inner and outer). Before I replaced any other bushings in my car, I did just this and my ride quality improved dramatically. Then get an alignment. I recommend SPL for the parts.
Third, have you had your wheels and tires balanced? Are your tires still good? Are any wheels bent? Any of these problems can cause unwelcome vibration issues.
I'm sure I forgot some things, but I'm sick of typing now.
Oh, and if you want to know if you have hicas, look at your steering column...there would be a Hicas indicator there if you did. Also, you'd have tie rods and a steering rack on the rear of your car...hard to miss if you peek under.
