S13/S14 Turbo timer wire colors
encasemyheart
Just thought I'd give a heads up, I just installed my Blitz Dual DC2 turbo timer today. I asked but no one seemed to know what wire from the timer went where, so I figured it out and am posting so if anyone else needs to know it will come up in the search.
Blitz Wire colorsBlue==>AccessoryRed==>12v constantGreen==>12v ignitionBlack==>GroundPurple==Handbrake
S13 wire colorsWhite/red stripe==>12v constantBlack/yellow stripe==>AccessoryBlack/white stripe==>12v ignition
S14 wire colorsWhite/red stripe==>12v constantBlue==>AccessoryRed==>12v ignition
The S13 install is very straight forward. Take off the plastic covering below the steering wheel and there is about 5 wires coming fro the steering wheel itself. Just tap the correct colors to the correct Blitz wires, hook up a couple grounds, tap the handbrake line and you're done!!
It works great and will double as my boost gauge.
