S13/S14 Trans plug questions
benz88
Car: 91 240sx
Alright boys and girls. Heres the situation. Im swapping a newer KA/Trans out of a 96 S14 into my 91, Now observing tonight i noticed the S13 trans has 4 plugs Versus the S14's only got 3. Now i need your guys help to tell me what the heck are what.
thier label;d by number so tell me what each number is on each trans thanks!
benz88
Car: 91 240sx
Up. Anyone? I need to figure this out asap.
benz88
Car: 91 240sx
Congrats on the help guys. But seriously, i did digging and found out thier all the same but Connector #3 on the s13 trans is a "Top position switch", I guess that'll stay unpluged. lol
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
a bit late, but whatever.
s13 trans:
1- neutral switch
2- 5th position switch
3- 4th (top) position switch
4- reverse switch
s14 trans:
1- neutral switch
3- reverse switch
you only need to wire the reverse, neutral and speed sensor for functionality. i would plug the hole in the trans. casing for the 4th (top) position switch rather than just leaving the switch unplugged.
benz88
Car: 91 240sx
diggles240 wrote:a bit late, but whatever.
s13 trans:
1- neutral switch
4- reverse switch
s14 trans:
1- neutral switch
3- reverse switch
Im using the S14 trans, so no need to plug an unused whole. I'll just have to ziptie the top sensor plug out of the way.
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
Correct. I mis-read your original post. I thought you had it the other way around....up too late :biggrin:
However, I would still use the plug/pigtail from the s13 4th (top) position switch to plug into your harness in order to seal your lower harness off from the weather. There is no need to have open connections, of any kind, exposed to the weather.
