s13/s14 subframe bushing for non-metal autox classes
All over the world, Nissan products are involved in road racing, track days, time attack and autocross.
hai1206vn
Car: 95 s14 se
Just to post what I found a while agohttp://mmr-direct.com/catalog1/S13/index.htm
About UHMW: http://en.wikipedia.org/wiki/UHMW
These are solid plastic bushings, almost as hard as aluminum, and help you fix that clunk in the rear and wheel hop, without getting bumped out of a racing class that prohibits metal bushings. They are made for s13 but will fit s14 as well.
As you see, MMR also makes solid UHMW engine + transmission mounts for pretty cheap.
I'm using their subframe bushings, Energy suspension z32 diff bushings, Nismo transmission mount and Windo-Weld filled motor mounts. All the slack that remains is probably from the motor/transmission mounts. No complaint about the MMR stuff, except that the rear end got a bit noisy for a street car (but it could also be my ring&pinion not meshing properly)
Btw I'd choose a plastic-metal contact over metal-metal contact (as with any aluminum part touching steel) because of galvanic corrosion possibility of the latter.
Modified by hai1206vn at 1:22 AM 12/10/2008
le_ryan
Car: Mazda3
91 Nissan 240SX SR
bump for more info, do you still hear any clunking back there, any other issues ?
hai1206vn
Car: 95 s14 se
The clunking is definitely from my pinion & ring gear backlash. I think that makes the rear end noisy during normal cruising/coasting too.
I'm pulling it out next week to get the side shims adjusted. There'll be an update soon
Right now it's the exhaust that is louder than everything else. I have BRM 2.5" and urethane hangers, with solid subframe bushings, so the drone at 60+ mph is a bit annoying.
hai1206vn
Car: 95 s14 se
So i got the diff re-shimmed to spec and installed it. It got quieter but I can still hear a bit of clunking if I let off the clutch fast (not dumping, just relatively fast) at wrong RPMs.
Yesterday I put in the rubber inserts sandwiched between the subframe bushings and the body (zerothread/302595, not made anymore) hoping to kill some more noise, but those only improved a little bit.
Well, having tried everything, it should be safe to say that the clunking will be there for any kind of solid bushing. On the good side, the little noise there is a good reminder of drivetrain shock whenever I don't shift precisely.
n00b240
Car: '03 6MT
For me, I no longer have any clunking of any kind coming from the subframe. But the differential clunks maybe 25% of the times I let up off the clutch. However, when Im driving faster/ autocrossing, quickly shifting I dont hear any clunk from the differential.
Ive got the solid aluminum bushings. I agree that for the solid diff bushing, there will always be some type of clunk for metal on metal.
I dont mind the subframe noise at all. Ive gotten used to it, and the car handles much much better, so ive got no beef. But anyone who rides with me, or if Im talking on the earpiece phone, its their number one complaint. Its too loud.
hai1206vn
Car: 95 s14 se
Yea I also got used to the final drive noise. My exhaust that's resting on the subframe and curious interior rattles are the things that bother me right now.
I'll be taking it easy on the drivetrain for some hundred miles before trying shifting faster, popping the clutch, etc.
As long as the subframe stays solid, I can accept the tradeoffs
n00b240
Car: '03 6MT
After I installed the bushings, EVERYTHING began to rattle. I found out that in the window regulator, some of the nuts werent completely tight (I swapped the window regulator myself), and the door handle screws were a lil loose. After tightening those, I heard no more rattles save for the pennies and coins I have in that center holding bay.
White Comet
Car: fc, s13 and mazda6, Sierra
hmm interesting to see these. i went with ES pineapple bushings, still non metal and they cost $65
hai1206vn
Car: 95 s14 se
it took me a long time to figure out why Japanese call those rings pineapples. Apparently they don't have whole pineapples in grocery stores.
Return to “Nissan Road Racing / Auto X Forum”
