S13/S14 Rotor Sizes - did a search
punch
I am switching to a 5 lug on my S13 and I want to use the stock brakes for now. Can I fit S14 5 lug rotors all around with my current calipers? I really don't want to drill the 4 lugs to 5 lugs. TIA.
Chingon
Car: 1991 and 1992 hatchbacks
I'm pretty sure you can.
Exar-Kun
Car: 2005 350Z
*shrug* good question, ask don at PDM racing, he would know.-chet
VitaminT
Car: 93 240sx SE
If you have not found out by tomorrow I will go compare them.
Dori Dori
Car: Cars of course
Yes you can, but if you have abs, you have to use abs rotors in the front (they are a little wider). The rears are the same no matter what.
VitaminT
Car: 93 240sx SE
I will measure them when I get home. I have S14SE ABS rotors and S13 non-ABS.
Nismo_Freak
Car: 89 Nissan 240SX
Yes, you can use the S14 rotors however you will need to use the S14 calipers because they are larger than the S13/S14 4-Lug calipers.
Dori Dori
Car: Cars of course
Are you sure about that NF? I was 99% sure that both cars shared the exact same brakes...*insert yoda voice* perplexed I am.:confused:
punch
Vitamin T, any result on the measurements? Looks like the rears will fit but the fronts....
