S13 & S14 intake manifolds
Redline240
Car: 95 240sx
Just wondering if both S13 and S14 intake manifolds share the same flange that bolts to the head...reason i ask is that i can get a S13 one for next to nothing and i'll cut the flange off of it to use in making a custom one for S14...i just wanted to keep mine in tact and i didn't wanna have to get the flange made up, and really don't wanna have to make one myself...
Redline
TrunkMonkey
Car: 2000 Lincoln Navigator
same flange.
-demetrius
Redline240
Car: 95 240sx
Thanks!
Redline
jmauld
Has anyone ever done a flow comparison between the two?
TrunkMonkey
jmauld wrote:Has anyone ever done a flow comparison between the two?
no need. the manifolds have the same design.
-demetrius
Redline240
Car: 95 240sx
What about the SOHC intake manifold? Just found out that the one i can get for cheap is off a 89...is it the same flange?
Redline
TrunkMonkey
Redline240 wrote:What about the SOHC intake manifold? Just found out that the one i can get for cheap is off a 89...is it the same flange?
Redline
no.
-demetrius
Rownan
demcj wrote:no need. the manifolds have the same design.
-demetrius
Remember the S13 KA has secondary butterflies.
Redline240
Car: 95 240sx
demcj wrote:no.
-demetrius
Well that sucks...what about altima's or hardbody's? Same flange?
Redline
TwinTurboPoweredZ
Car: Cars, Women, Sex, and sleeping
Redline240 wrote:Well that sucks...what about altima's or hardbody's? Same flange?
Redline
Alitmas and the trucks use diff intake manifolds, they are same engine but has diff mani's. The ones on the truck looks like a carburator (even thos its efi).
Redline240
Car: 95 240sx
It doesn't matter if its a different manifold, as long as the head is the same then the flanges should be...both altimas and hardbodys have the DOHC, so isn't it the same head?
Redline
Redline240
Car: 95 240sx
Redline240 wrote:It doesn't matter if its a different manifold, as long as the head is the same then the flanges should be...both altimas and hardbodys have the DOHC, so isn't it the same head?
Redline
Anyone?
Redline
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
no, all the dohc are not the same. The altima and truck dohc head have a smaller front cover assembly and different distributor location than the 240sx. The altima head has the main water passage on the exhaust side of head, as well as the casting in the back for the cam driven distributor mounting. I would assume the flanges both intake and exhaust on the truck and 240 heads are basically the same. Valve covers arent interchangeable on truck and altima. They all most likely use slightly different cam profiles as well.
They are all basically the same and components valves, cams, springs, retainers, etc... are interchangable.
