S13-S14 front lower control arm interchability
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
95 S14 base
Recent drifting accident bent the driver's side front lower control arm, was wondering if they are interchangable with the S13 arms. Did a search, only post that came up one guy said they did interchange, the other said they didnt please help, thanks
MMotorsports
Car: 1989 nissan 240sx with SR20DET
Sorry it took so long to get an answer did not see your post. But well with all my knowledge no they will not the s13 is different than the s14.But I will check my books for you.
Modified by MMotorsports at 1:50 AM 1/11/2008
Hijacker
Car: '92 240sx Convertible
'94 F-150
The arms are the same length. The ball joint is different. The S14 utilizes a different taper than the S13, and that will cause bad things to happen if you try to use it on the wrong chassis.
SX APPEAL
95 Maxima SE 5MT
OK well thanks for the help guys!
