I'm looking to get a dedicated HPDE car in the future since the thought of wadding up my M3 makes me more than a little nervous. BTW - when I say track, I mean road course for all you drag racing fiends out there.
I've always loved Nissans, so I've really been looking at an S13 240SX.
Just have a few questions for the people that have really pushed their S13's:
1. How is the braking on these cars? I see alot of people upgrade to Z32 brakes. How cheaply could one do this via a junkyard and a little bit of patience? What size are the Z32 rotors, are they vented front and rear?
2. Are there any glaring problems with the S13 suspension design? Any bushings that fail under hard use, are they hard to change out? For instance, on my car, the rear trailing arm bushings can fail with heavy use and then rip the carrier out of the subframe. It costs about $2k to fix this! Needless to say, I couldn't deal with a repair of that cost on a car that isn't worth much more than that.
3. What is the widest set of wheels and tires you can fit in the fenderwells with slight rolling of the fenders? I'd probably use 16" wheels with something like Azenis at the beginning. Any chance you can fit something monsterous like a 16x8.5 or 16x9" wide wheel under the stock bodywork?
4. How light can you feasible get an S13 with minimal options by taking out things like backseat and spare, go to a lighter battery and any other "cheaper" ways to reduce weight. 2500-2600lbs sounds really nice if it's possible!
5. I'm really intrigued by the chance of an engine swap to bolster power down the road. I wouldn't immediately spring for more power when I got the car, because power is probably the last thing you really want to improve when out on the track(brakes and handling come way before that). Yet is there a chance one could do a CA18DET or SR20DET swap for ~$2k, or is that too little? I do all my work myself, so a drop-in swap of a 4 banger doesn't sound all that hard. Nothing a weekend and a case or two of beer can't get out of the way.
6. Last but not least, I'm 6'3" with a relatively long torso. How is headroom in these cars without a sunroof? How about headroom with an SA rated helmet? That would take away about 1.5" of headroom. I suppose I could try to get a fixed-back seat to save weight and get me closer to the floorboard, but is that even going to be a real tight fit?
Anything else you guys want to add, feel free.
RWD and light weight sounds awesome. I just need a fun car to do HPDEs with that isn't too expensive to mod and wouldn't make me want to kill myself if I managed to be stupid and wad it up into a wall, and an S13 sounds like it's the ticket!
Thanks in advance guys.
