S13 running on 3 cylinders HELP!
Ericb
Car: '91 Nissan 240SX
Just picked up a 91 240 last week and all was good until it started running on 3 cylinders. I replaced spark plugs and wires the day after getting the car, when it started running on 3 cylinders I replaced the plug in #4 cylinder since it is the one not working. and the problem still existed.
A friend's s13 was doing the same thing last week but then went back to normal. is this a common problem? if so how can I fix it?
94_240sx
Car: 94_240SX
Most likely, it's an injector. Yes, it's a common problem. Go to a junkyard and pull a couple of them. You must use new o-rings. It's okay when the engine is cold, but doesn't work when it's hot. At least, mine acted that way. Yeah, I've replaced 3 of them so far.
Ericb
Thanks, I was thinking it was possibly an injector. I searched and couldnt find where anyone has had the same problem. Now I wish I wouldnt have sold parts from my old KA.
Hopefully thats what is wrong with it.
WoolyS14DET
Car: 1998 Nissan 240sx w/SR20DET
Simon says get a new injector !!!!
Ericb
I plan on it. hopefully some of my RB powered friends still have KA parts laying around.
WoolyS14DET
yes that would be your cheapest route !!!
Ericb
and most likely free, it makes me sad, im the ONLY KA powered 240 around here. all my friends have RB's
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Change your cap and rotor too. That is a maintenance item that hardly ever gets done on our cars.
Ericb
it was changed before i bought the car, old one was still in the hatch area
DRIFTMUNKY
Car: S13 Silvia
I had this problem with mine..i switched injectors but the same cylinder still wasnt firing..so what i did was got a volt meter and checked the plug on the injector harness...turned out it wasnt putting out anything...so i traced the red wire (positive) on the injector plug and found that it was corroded away....it wasnt even connected...soldered it up.works like a charm
