Nissan87 »
https://forums.nicoclub.com/nissan87-u121618.html
Thu Feb 25, 2010 6:45 pm
I'm having trouble removing the eccentric washer off of the eccentric bolt on the chassis side of the rear upper control arm. I've tried spraying it with Freeze Off (similar to PB Blaster) and hammering the end of the bolt to try to get it to slide out, and also tried to pry the washer off with an allen screwdriver.
I'm thinking that I need to twist the washer off the bolt because it's stuck from being twisted onto the wrong side of the eccentric bolt, but I'm not sure how I should go about doing that.. Or maybe a torch would do?
Anyways here's a pic for better reference:
