s13 RUCA install
xagna
Got myself a set of s13 ruca. I would like to ask those who have done this s13 ruca install before and would like to share their experience.
What are the things and comman problems that I have to be careful of or can avoid?
And for s13 you have to remove rear coilovers or damper strut, right?
Neejay
Yeah, you'll have to remove your strut/coilover.
From what I remember, its easy to install, just like 5 bolts (including lower and upper strut bolts). Just make sure you make the RUCA's the same length of the OEM RUCA's at first. The hardest (which isnt hard, just annoying) part is putting one on and having to take it back off to adjust it some more.
Just examine the OEM one carefully before you take it off and install the RUCA along the same lines.
Piece of cake.
xagna
Thanks for the advice.
Do I have to put some grease on the Hiem joint?
