S13 right head light doesn't work need help asap!
Idahos13
Car: 93 240sx hatchback
Hey guys I got pulled over the other night for my head light being out. I have tried everything to get it to work. I checked all of the fuses, relays and the bulb is good. The problem is there is power coming out of the head light plug when the bulb is out, but when we plug in the bulb it's like it grounds out the power source and the head light doesn't come on.
I need to get this fixed really soon any opinions will be appreciated thanks!
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
might be the light stalk....check if any other lights are out around the car
Idahos13
No other lights are out. just the front right headlight.
Cbus240
Car: 89' 240sx SR20DET
My buddys 89' s13 was having the same problem, both headlights would pop up, but the passenger side wouldnt illuminate. It would however, light up if he turned his brights on, kinda weird. Well, I did some searching and found this great write-up here on NICO on how to fix your switch, and after what you've stated, it seems the culprit could very well be burned contacts inside your HL switch on the column (nothing serious, just from years of everyday use). He followed the write-up exactly and it worked for him, check it out, it's pretty simple and wouldnt hurt to try. Good luck!
zerothread?id=280461
Idahos13
Thanks, but I don't think it is that. Because we had a voltage reader and it said there was power through the plug, but when we pluged in the bulb its like it grounds it out because there is no power after that. But it wouldn't be worth a shot.
Idahos13
I cleaned the little terminal things inside of the head light switch now all lights work even high beams which I did not have before. But now I have a different problem, now none of my turn signals work! I need help asap!!
nightsauce
maybe your fuse it out for the turn signals. If not, I know that when the hazard switch harness is not connected to the switch the turn signals dont work. Check those two thingys
Modified by nightsauce at 10:17 AM 12/2/2009
Idahos13
Everything works correctly now.
dsastr_clan
Car: 240sx
glad to hear that, but what did u do to have everything work properly?? how did u clean ur terminals and what terminals did u clean??
Idahos13
Cleaned all the terminal contacts. with a dremel wire brush kit.
