Project S13 »
https://forums.nicoclub.com/project-s13-u21998.html
Thu Apr 07, 2005 5:17 am
Alright guys, my friend thought it'd be cute to buy me a pivot headlight controller, so we decided to install it a while ago. I never got around to asking this question. When you use it, you set where the headlights will stop and then turn them on/off to get them to raise and then lower back down, stopping at wherever the switch is set at.
That part goes fine, but the problem is, one starts going down slightly before the other, but they both stop at the same time. I believe this is the way the car works and that it did that normally, but since they would go all the way down I didn't notice it. So my sleepy eyes are lopsided. Of course I can use the little knob on the motor to manually fine tune the look, but...that defeats the purpose a bit.
Does anyone know if I can tighten up the lights or anything so that they will pivot up and down in more unison? It's not terrible, but it is noticeable from a ways away. I imagine this would be the case if you used a toggleswitch or a pivot unit.
