Original Owner 90 S13 Hatch.
I just had a complete set of Energy Bushings replaced in my Car along with New Kyb Struts, Mounts in the front and rear. Also new control Arms, Tie Rods, Ball Joints (Front & Rear). My car has 200,000 miles and I was hearing a clunking sound in the rear when shifting along with other noises. Well after everything was replaced including the Energy Subframe insert. ($900 Labor for the job, he said it took 6 hours just to get the old bushings out and install the new ones on the components.
I still hear the noise in the rear plus others.
We had the car up and as I let the clutch in and out you can see the Subframe jumping all over the place. So now he says I have to replace the Subframe bushings that is going to be very expensive and involved. I looked up the Energy bushings and they only cost $18 for the set, this is not the inserts that came with their bushing kit. $18 seems so cheap compared to the price they charge for the S14. http://www.energysuspensionbushing.com/ ... ctid=30293
Any suggestions on Subframe bushings? Are these OK to use? I cannot remember I saw a post someone used a Z32 (that could be wrong).
Is there any other way to fix this problem then taking the subframe out like my friend told me? He was not sure if the subframe had to come out but thought it did
Would a Collar do the job?
The car is my daily driver that I have fun with every now and then. Sorry to sound dumb but I do not know anything about Suspension.
THANKS
THANKS
