S13 Redtop Stock T25 to S15 Turbo Upgrade
Silverbullet91
Car: 1991 240SX SE Coupe w/sr20det redtop
Hey guys! I’m getting ready to do a S15 turbo upgrade on my car and I wanted to get some questions answered first. Before you flame me about not searching let me say I know some of these questions have been answered before. However, this seems like a likely upgrade for some to make so I was thinking if we could get some good responses to the questions in accurate detail then this would make a really good sticky.
I have an s13 with a redtop, stock t25, greddy hotpipe and front mount.
Will Taka Lines for a s14/s15 turbo work with redtop engine?
Will I need any kind of oil restrictor for the s15 turbo?
Do I need both the s15 compressor inlet and outlet or will any of the s13 components work?
Will I have to cut any of the inlets/outlets to use my greddy hotpipe?
virus77
Car: 95 S14, 71 240z, 97 e320
Will Taka Lines for a s14/s15 turbo work with redtop engine?Will I need any kind of oil restrictor for the s15 turbo?
If you use taka lines you need the oil restrictor, if you use the factory hard lines you dont need the restrictor (I used the factory hardlines)
you need a s15 compressor inlet and outlet pipe or you can cut and reweld your pipes to work. I just tweaked my custom intercooler piping a little and made a new intake with some 2.5" bends.
the hotpipe is not going to match up to the turbo outlet so some cutting/rewelding/coupling will have to be done.
Basically there is a few ways to do this, I chose the cheapest way
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
To get my hotpipe to mate up to my t28 i got the 45 degree rubber elbow off of the stock hotpipe and put that on the turbo outpipe and then just cut my greddy hotpipe so it would go straight into it. It was very easy.
Silverbullet91
Wow, you guys are quick with the responses. Thanks. I'm confused by something. Virus, you said if I use the hard line I won't need an oil restrictor. Why? Does the stock hard line have a restrictor built into it? If thats the case why did you post in another thread that the turbo has a restrictor built into it?
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Silverbullet91 wrote:Wow, you guys are quick with the responses. Thanks. I'm confused by something. Virus, you said if I use the hard line I won't need an oil restrictor. Why? Does the stock hard line have a restrictor built into it? If thats the case why did you post in another thread that the turbo has a restrictor built into it?
I know I don't havea s15 t28, but I ordered some taka lines for the t25. If you have to have an oil restrictor for the t28 do you also have to have them for the stock t25?
virus77
it does have a restrictor but its seemed that people with taka lines needed a restrictor with it to work. I have no personal experiance using taka lines but thats what Ive heard from people using them. Ive been running the stock hardlines for 18k miles on a s15 t28 so I personally know thats a winning combination
wildacexxx
Car: 2002 Q45 nav sport
I ask good questions wrote:To get my hotpipe to mate up to my t28 i got the 45 degree rubber elbow off of the stock hotpipe and put that on the turbo outpipe and then just cut my greddy hotpipe so it would go straight into it. It was very easy.
will this be needed when using a s14 t28 also?
Honestly I couldnt answer your question. I just found out that I have a t28 instead of a 25 when i ordered a hotpipe and it would fit then i got to doing some research. Im also not sure whether or not i have a s15,s14, or pulsar gti-r t28. My motor came with it and i know its a 28 from the a/r .60 and the stamp that sais m24 on the compressor housing. If im wrong let me know. Also not to thread jack... How can i tell what t28 I have visually without taking it apart
2_Liter_Turbo
if you take off the turbo elbow, look at the turbo, and if there is a divider between the turbine and the wastegate, then it is an S15 turbo.
karmakaze
Car: 98 240sx SE
i thought the t28 turbos had a built in oil restrictor? at least mine does.
Silverbullet91
Virus,
So you're saying that the turbos have a restrictor but the Taka lines need an additional restrictor in order to work properly? Does anybody think the Taka line are worth the extra money?
Dori Dori
Car: Cars of course
Taka lines come with a .035" restrictor IIRC.
virus77
Silverbullet91 wrote:Virus,
Yup
and the s14 t28 is the same as the s15 t28 as far as installation is concerned
wildacexxx
^^did u have problem with your hotpipe or did u do it all in one swoop and never used the t25?
blackboost
hey virus can u im me ? i hava question for u .. thanks enticincharm
virus77
I never used the t25, I have custom intercooler piping from the KAT I used to have to I just moved it around a bit to match up to the GT28R.
Im never on AIM, email me if you want at [email protected]
