Good Evening/Morning all,
This is my first forum post so excuse me if I’m ignorant in regards to forum procedures.
To begin I purchased this car non running and after discovering a no spark issue I managed to get it running after re-installing the crank angle sensor. I had it idling/revving for about a minute before i realized the water pump was pissing coolant and then after a good rev the boost piping blew off. I replaced the water pump and fixed the piping and after starting it up again I noticed a severe hesitation issue upon sudden actuation of the throttle from idle (no hesitation if throttle is applied as the rpm’s dropped) and the temp gauge had stopped working. Spent several months chasing red herrings, before recently, no more spark again. I tried again to re install the CAS to no avail, however when i plugged a separate one in and turned it by hand I would receive spark. At this point I’m lost and am looking for some help. It seems preposterous that it could be relevant but I’ll add that i removed the connector to the IACV and after plugging it back in again the no spark issue returned. Car has power FC ecu. My best guess right now is there’s some sort of voltage draw somewhere while cranking that is barring the CAS from receiving enough power to signal to the ecu to fire? I’m not the best with electrical diagnosis so any help would be appreciated.
