EvillE423 wrote:When I bought the car, the rear wiper worked normal. Here lately, it would work intermittently. Now it wont work at all. I looked for a fuse, but couldn't find one. Anyone know whats wrong? When I push the fluid button, it will spray fluid out but it still won't come on. When the switch is one, it doesn't make any noises or anything. I'm clueless
I would first check the power at the switch, if you have power at the switch then check the power at the motor, if you have power to the switch and not the motor, then the switch could be bad, I would buy a new switch. If you have power at the switch and motor, could be a bad motor, I would buy a new motor. And, check all grounds too.
Part #'s
Switch: 25260-40F00 List $32.83Motor: 28700-40F00 List $277
Pricey, but it will no doubt be a good part.
