Looking to see if there's any info if all the control arms are interchangeable or not between these two cars, before getting half-way through swapping stuff to find out something doesn't fit. Already swapped the front tension arms in cause I think that's a no-brainer, and the back looks pretty do-able....so I'm curious. Searched and found stuff on the front, but not so much on the back. Any info would be good....thanx
SINCE NOBODY KNEW THE ANSWER TO THIS I TRIED IT...AND IT ALL WORKS. SO IF YOU HAVE SOME PARTS OR SOME STUFF YOUR TRYING TO SELL, YOU CAN BROADEN YOUR FIELD. FTW
