kasey24e wrote:Sorry to thread jack, but which direction do the rear speaker covers pop off? I've pushed and pulled pretty hard to no avail, I don't wanna break em. Thanks.
I believe its called "necro-posting" or bumping dead/old threads, but no worries
The speaker covers have 4 tabs, they will pop off pretty easily if you put a slotted screwdriver between the cover and the larger plastic base. They pop off sort-of straight up, towards the hatch glass. It definitely takes some effort, the first time I was convinced it would break, but it'll hold together, just pry towards either eend where the clips are, probably more support there than at the center.
You really only need to use the screwdriver to get it loose from the two tabs towards the center of the car, once those are gone the back two can be removed by hand.
