Asakura »
https://forums.nicoclub.com/asakura-u97477.html
Tue Sep 21, 2010 2:27 pm
So I was driving home the other night and it was cold and raining, so I turned on the rear wiper and defrost. It worked for about 5 minutes then both of them just stopped working all together and I could smell something burning. I've since discovered that my brake lights don't work either, but my parking lights do. I've looked over the wiring and fuses, and I had to replace the 20A RR DEFOG fuse but all the others were good. The bulbs are all good, the gromet going from the hatch into the car isn't chopped or anything, so I suspect it could be a bad ground. Since the defrost, wiper and brakelights aren't working, is there a main ground somewhere I can check?? Has anybody else had this problem before? Not having brake lights is scary and illegal so I want to have this fixed asap.
thanks in advance
