s13 rear brake upgrade?
chris_240sx
Car: 1995 240sx
im goin to be installing the Q45 rotors and calipers up front and i was wondering what i should do with the rear brakes....what are you using in the rear or what is a good upgrade? i was thinking just some better pads or maybe some slotted rotors???other options? thanks
Exar-Kun
Car: 2005 350Z
some nice pads, ss lines and slotted rotors will work just fine.-chet
chris_240sx
Car: 1995 240sx
thanks ill give that a try
Exar-Kun
Car: 2005 350Z
try and find some axxis ultimates, its a great pad for street/light track.-chet
180fan
Car: 89 fastback
or you could try to get some endless pads. a buddy of mine bought his for 100 a side...
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
i believe there is a member here on nico who has his website (kadevelopment.com) or something like tha and if i believe correctly he has supra brakes in the rear. you might wanna run a search on that.
~swave
POS_S13
Car: thizzlamics
aren't 180sx calipers bigger than 240 calipers?
hannibal
Car: Red Line to Glenmont
IIRC, silvia K's had bigger brakes than 'lesser' silvias. dont know how this applies to the 180sx.
posted by Dauer in another threadI fell your pain, I too am on a quest to know what wheels clear the z32 brakes or in my case s14 silvia K's brakes which are identical to 30mm z32 brakes.
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
f4o calipers work, just gotta get bigger lines, rotors and clearance ;)
barrigas14
hawk pads. endless too much money. bad experiances with axxis...too much brake fade.
180crafter
Car: Nissan 240sx
D1SR240 wrote:i believe there is a member here on nico who has his website (kadevelopment.com) or something like tha and if i believe correctly he has supra brakes in the rear. you might wanna run a search on that.
~swave
we need to get this guy to tell us what he is doin!!!
daniel
why?
whats wrong with Z32/R32 rear brakes?
they ebrake locks so fast omfg its not even funny.
those with some R4-E pads would ROCK. yeah....
I like HC Titan Kai for the front but they eat rotors like a raver eats pills
180fan
Car: 89 fastback
hmm what's the operating temp range for the Titan Kai's? If you're using pads that aren't built for the right operating temps, you'll shorten pad and rotor life
daniel
haha bro
dont worryits fine
they're just full titanium/carbon so they eat rotorsregardless
haha project mu makes a special rotor to use with that pad i just dont have the money or care enough to use it..fyi
hc titan kai is like 0-800*c
180crafter
Car: Nissan 240sx
Beacuse I have a full suspension that I am not willing to part with for z32 uprights.....
daniel
you dont need the ****ing uprights to run Z32 rear brakes
whoever told you that is retarded.
Exar-Kun
Car: 2005 350Z
I'm pretty sure you have to use the Z32 spindles for the caliper and stuff to bolt on....esspecially the parking brake...-chetSCC did their write up, and had to use Z32 rear alluminum spindles.
sapix @ RHIT
They used the Z32 rear suspension because they wanted to save the weight with the Z32 uprights. The brake upgrade doesn't require the change. Even a five lug swap in the rear doesn't require the Z32 uprights.
Dori Dori
Car: Cars of course
Stock spindles work, you just have to mount the new p-brake hardware.
Exar-Kun
Car: 2005 350Z
wlel, I knew you didnt need them for the 5 lug conversion, but I was under the (apparently mistaken) impression the caliper didnt bolt into the rear s13 spindles.
oh well, lesson learned :)good to know!-chet
180crafter
Car: Nissan 240sx
Dori Dori, Thank you for the seemingly civilized answer.
Danny-boy... Calm yourself. You do not need to be such a bastard.
daniel
im not a bastard.i am tired
very tired
of WRONG INFO being spread around...seriouslywhy the hell would you need to put the spindle on? its pointless..and anyway..it doesnt help any.
Z32/S13/A31/Y32/C33/R32(only some model) sus interchange 98% of the stuff.. all Z32 and S13 is the same save a few balljoints here and there...hell you can even get a R32 GTS-t M rear subframe and bolt it up to S13..its to stiff though.
S15 subframe is a lot better...but you need S14 arms for the rear
see what i mean?
alsoif you're using Q45 rotor/caliper in front stock brake will be fine, but Q45 rotor/caliper is a waste...might as well spend the same money get Z32 f/r
also
Silvia K brakes are 1" bigger in diaooooo
haha
crzycav86
Car: 93 Nissan 240SX KAT
I'm putting the z32 rear knuckles on my car this summer... as well as the rear brakes, vlsd, and coilovers. And I'm staying 4-LUG. Less unsprung weight will give better handling and response... it's not useless. All you need is to change a ball joint and the rear casings..
Also, the aluminum spindle is about 8 pounds lighter PER SIDE.. a significant unsprung weight savings...
daniel
uhcrzcav86
how are you planning on putting Z32 VLSD? please tell me
it is R230Vwhich is 230mm
s13/14 etc., et.c, isR200
200mmplease tell me how you are planning to do this!thanks!
unless the n/a model has R200??
Exar-Kun
Car: 2005 350Z
"how are you planning on putting Z32 VLSD? please tell me"
how about you check the 240sx.org installs.
also, you need to seriously chill out man. allunmimun Z32 spindles are nice to have, weight savings, esspecially unsprung weight savings, are always good. relax yourself, I'm sure I was not the only one under the impression you needed the spindles and such to complete a rear 300zx brake swap.
also, as for the q45 verus z32 thing you brought up, I suggest you check the article in GRM(conveiniently in the thread "read this or be beaten.." seeing as how the stock 240sx brakes are capable of locking tires up, and people complain about the extra "compliance" in a Z32 setup, even after the m/c swap(since the MC is alrger, it requires more effort...)
the larger than stock 240, larger rotor q45 brake setup seems quite logicall and a great choice if you dont think you'll overheat them(and 99% of the population wont..those brakes were on a 4500lb car, after all...)
so relax man, you're new here, try not to ruin your welcome so quickly. we're all here to learn, even if we think we know everything///
"the minute you think you know everything, you know nothing"-chet
daniel
jesus
i didnt know you could use 300zx vlsd
i knwo the turbo model has R230V because i used 4 of its input flanges on a R230 install in a S30
see..loook at the last line in my postand
seriously i never said stock brakes were bad
1. i like z32 brakes because i have em laying around2. i like z32 brakes because they have drum actuated rear ebrake which locks faster than oem lot more fun k?3. i like z32 brakes because teh rotor is thicker, i really want to get some Z33 calipers and run those.
crzycav86
daniel wrote:unless the n/a model has R200??
Correct. (owned)
crzycav86
daniel wrote:jesus
It's ok. You were wrong.. no need to get your panties in a bunch. We're all here to learn, and we all make mistakes....
See? You learned something... With a little more humility, you're likely to learn even more.
Exar-Kun
Car: 2005 350Z
It's cool man, I learned something, we're all here to learn :) I understand why you want to use z32 brakes, I'm just telling you why people go with the q45 brake upgrade :)and yes, you're right, the intergral rear drum parking brake is fun on Z32 brakes...more of a drifting consideration than anything., if you use the e-brake/parking brake to drift :p
Keep on keeping on man, its good to have a knowledgeable person around :)I always allow myself a moment of question(I dont know everything, I still buy books, read articles, etc) or specualtion whevner I say something..like the spindle thing, the only reason I thought that was the SCC article and the guys at bapo use them for their conversions, I had never heard or read anything otherwise, but it turns out you dont have to...which when I think about it is freaking sweet.relax and have fun :)welcome to NICO-someones always smarter than you, except repo man, he's not smarter than anyone.-chet
crzycav86
You guys may have already read this, but I'll post it again: http://www.nissanperformancema...40sx/ It talks a little about using the z32 knuckle, and how to use it.
And as for the rear z32 brakes.. I'm just using them because I have them laying around. It's not really worth it to sell them because no one really wants them.. just the fronts. :)
