S13 Rear brake upgrade?
Danrc30
Car: 93 Nissan 240SX convertible
81 Nissan 280ZX-T
85 Nissan 300ZX-T
I upgraded my front brakes on my 93 vert to the Q45 mod, and I'm wondering if there's a comparable upgrade for the rear. One of my calipers is frozen so now is the time! Please let me know asap!!! Thanks!!!
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
Nobody knows???
EPD
Car: 94 caged vert, 87 RX7
the only one i am aware of is the z32 mod.
since your car is a street car, not a track car, you dont need a larger rear brake set up, plus the majority of the braking is on the front.
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
Well, since doing the Q45 upgrade in the front, the front locks up a lot easier now. I was hoping to upgrade the rear to offset the unbalance. Do you know if the Q45 calipers fit the rear as well?
simmode1
Car: Red '95 S14
You could do STI Brembos with Evo rotors... Overkill maybe?
yokota180sx
Car: 1997 Stagea RS4, r34 front
get hte correct BMC and the problem will go away...
hai1206vn
Car: 95 s14 se
simplest way is using grippier pads in the rear
Nacho_240
Car: 1991 240sx LE
Have you considered using the same calipers but bigger rotors and calipers brackets? PBM sells a nice set. I'm not too sure if having such big rotors on a small pad will benefit much though.
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
I'm just going to get a set of rebuilt stockers for the rear. They're expensive enough as it is!
94_240sx
Car: 94_240SX
yokota180sx wrote:get hte correct BMC and the problem will go away...
Yup! You need a right size proportioning valve.
You can consider this one in the future. This could be what you want. Stock calipers with Cobra rear rotors.
http://phase2motorsports.store....html
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
Explain the valve?
As far as the rotor upgrade... yea, maybe someday... not in this economy though!
94_240sx
Car: 94_240SX
Danrc30 wrote:Explain the valve?
Propotioning valve is attached to Brake Master Cylinder on s13. Upgrading it to z32(300zx) BMC will definitely help. It's a direct bolt on and you don't have to bend hard lines. Only problem is 3rd fitting, but if you search hard, you can find one with 3rd fitting pressed in. If not, you can take it out from s13 BMC and move it over.
ANVIL
Car: RB25DET S13.5
what do you mean by 3rd fitting? i have myself a q45 F brake upgrade, i havent installed yet and looks like i want to do the bmc too now, to make it a better upgrade
94_240sx
Car: 94_240SX
ANVIL wrote:what do you mean by 3rd fitting? i have myself a q45 F brake upgrade, i havent installed yet and looks like i want to do the bmc too now, to make it a better upgrade
http://www.importnut.net/300zxbrakeswap.htm#MC
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
Ok, so I got my calipers in and I'm putting the brackets on. I greased up the shafts and put the rubber boots on, but now I'm stuck. I'm about to put the 2 bolts in that hold the bracket on and I notice that the kit came with 2 crush washers. "Crush washers???"
Do these washers go on these bolts to seal the grease in or something? If so, which side do they go on? I didn't notice them on the original calipers.... help?
Warped161
Car: 90 s13 the never ending project
If they are the copper ones they should be for the brake line.
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
But why two of them in each package?
Warped161
one on either side of the bolt that holds the brake line on.
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
D'oh!!! Man... this week at work must have been worse than I thought! ugh!!!
Warped161
No problem, it happens to us all.
94_240sx
Car: 94_240SX
^^That's the best looking Q45 caliper I've ever seen. Nice job.
EDIT: fixed
Modified by 94_240sx at 8:29 AM 11/14/2008
Warped161
actually thats my front q45 caliper, but the brake hose setup is the same.
94_240sx
Car: 94_240SX
Warped161 wrote:actually thats my front q45 caliper, but the brake hose setup is the same.
Oops, sorry. What I meant was quality of finish and rebuilt.You know...
