S13 Rear Ball Joint?
rico05
Car: 1992 RMS13 w/ CA18DET
Just wondering if anyone has had any luck finding a replacement other than a new RLCA from Nissan. I have heard that B13 fronts will fit the S13 rear, and I have a set of them sitting ready to go, but I wanted to be sure before I spend the sweat and knuckle meat popping those little bastards out.
I already replaced my fronts, and Jesus....that was not fun at ALL.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
There are some aftermarket RLCA's from Orangetree as well as a few others but they will all run you $400 and up.http://phase2motorsports.store....html
gumby74
I would like to know if this works out as well. The rear balljoints are about the only thing I've not yet replaced.
I have seen some eccentric balljoints for the rear on eBay for about $150 shipped. Right now I am calling that plan B.
So git-r-done already and let us know for certain that this is a viable option.
rico05
Well, a guy on Zilvia used some B13 fronts and for the last several weeks (and a drift day) they have held up. I will probally try this next week (when I have the time).
Apparently, the actual ball is 1mm bigger on the B13, but the overall size is the same. The shank on the shaft matches, and the threads on the shaft match as well. We shall see.
