s13 rb26 track times
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
so i figured out my e01 problems on the way out to the track last night, i got 18 runs in, fastest was a [email protected]
r/t .09560ft 2.299330 5.7671/8 8.374mph 97.171000 10.5221/4 12.324mph 125.47
i had boost set at 17 on completly stock tuning, stock mafs, stock injectors, watched my wideband the entire run never rised about a 11.2 thru out the entire pass. sorta happy with that, now all i need are some good tires and allot better 60ft time. i think 11s are very possible with the stock ecu
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Ya dude you are Dying in the 60' With good tires you will be deep into the 11's I would say 11.6's to be exact.
Sounds like she's running good!!
StricNyne
u 2 guys call each other last night ? .... ne way impressive times man !!
WhatsADSM
Car: 1998 240sx
Nice MPH!
Get some real tires and that is a DEEP 11. I'd bet you go at least mid 11s with a nice launch on some DRs.
Also what turbo is this? You have a full mod list? (sorry just joined the boards again after a long time off so not sure if it has been discussed before)
WhatsADSM
Car: 1998 240sx
BTW 11s on stock computer... I'd bet with some real sticky tires (read 1.6x 60') and a touch more boost you got a chance at a high 10 with the stock computer.
Shocker
Car: 89 240sxHB rb26/30
what turbo/(s) are you running?
SullivanRacing06
im running a greddy t-78 33-d turbo, i have a set of 275-35-18 toyo t1r on the rear and 245-40-17 t1r on the front, so its got some tire on it, ne suggestions on a set of slicks?
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
dam i was about to say with all the stock stuff you have i was kind of concerned about my rb26 cause i trap at 113mph but i run 12.2 with 1.8 60' but get some slicks and you will deffinitly see the 11's.
gawdzilla
Car: none
that's a lot of mph for stock injectors... 100%+ duty cycle?
DETurbine
Car: Nissan S13 RB25
Get some MT Streets or a pair of slicks and drop that 60ft.....other then that it's looking good. What kind of suspension are you running?
SullivanRacing06
im not sure about the duty rate, i have tein basics for suspention with st sway bars, id like to get some slicks but then id be worried about breaking a axle
