I bought a used pump that was told to be from a S14 (I just wanted it to be non HICAS and compatible with the bracket), but it seems not beeing a S14 one.
The more I look at it the more I think I shouldn't have bolted directly the pressure line to the connector outlet bolt. There is probably a missing part, called joint-outlet, that has the perfect thickness for the connector outlet banjo bolt, to let the valve assy flow control be perfectly settled between the spring and the bolt and work correctly. But to find this part I need to know exactly where my pump comes from.
Here is the pic of a similar part I'm talking about:
And here are some pics of my pump for NISSAN specialists: it's written 26YA K9 on it:
And for those interested by pics of the whole engine:
THanks for your help!
