S13 RB25DET tachometer problem.
UndftdSole
Car: 90' 240sx RB25DET, 07 Subaru WRX
hey guys i just finished an RB25DET swap into an 90 hatch. and everything on the cluster works except for the tachometer. i need help to fix it. do i buy an aftermarket one or is there a way to fix this?
Modified by UndftdSole at 10:00 AM 12/14/2008
d356bud
Car: 1990 240sx w/ RB25DET
get a tach from a 91-94 and adjust the pot on the back until its correct
ANVIL
Car: RB25DET S13.5
lsauto.com sells a precalibrated one.
also if you want to be cheap like me, grab a j30 tach and put it in your cluster. the fitment is really close but not perfect. some people also use maxima tachs, but the fitment on those are horrible. i was using one until i found out about the j30
Neejay
d356bud wrote:get a tach from a 91-94 and adjust the pot on the back until its correct
Have you confirmed that this works on a s13 91-94 dohc cluster?
I've only seen this confirmed on s14 clusters.
EDIT: I'm still going to go with Carl H, but I need to spend my money on getting a replacement turbo and injectors first...so as a temporary solution, if this will work, so be it.
