S13 RB25det car turns off while driving?
RBS13_Andres
Car: s13 rb25det
sooo i recently swapped rb25det into my 1989 s13.. no big mods just fmic, walbro, fpr, full exhaust... as im driving usually in third gear i do a quick pull and it shuts off.. turns right back on no problems. anybody know why its shutting off ? might be timing, car isnt idling like it should also
meet07
Car: 89 180sx rb25det
Download the FSM and check all of your connections that has something to do with idle like tps, mat, adjust your idle per FSM and go from there. I know mine cut off after running for a while due to bad battery ground from chassis to battery.
Good luck
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Does it do it after car is at normal operatin temp? Does it happen when cars still cold? The reason I ask is because a MAF will cause that issue before it dies out. Your showing the begining of maf death. It will die when coming off a load. Easy to restart but Will keep shutting off when driving untill carcis cold again. Keep us posted
