opticnerv wrote:check to make sure your throttle cable isn't sticking on your hood. Happened to my car I took my dremel and cut the section of hood skeleton that was squashing the throttle cable. If thats your problem you'll see the markings on the hood
Thanks, for the tip, but thats not the problem.
He put about 50 miles on the car. The afr's at idle are a little better, but still jump around alot. its around usually 14:1 sometimes will go down to 12:1 and then sometimes jumps back up to like 16:1.
Still breaks up/stutters under boost, but I think it might be from lack of tune.
