thank you for answering the question but what about the RB25 transmission crossmember on the s13 chassis? How will it sit and does it bolt on too?Kamin wrote:welding what? it bolts on fine.
well, it got the m/t sohc s13 crossmember, and the rb25 crossmember. can I still use the rb25 mount or do I have to use the s13 crossmember?Kamin wrote:the transmission mount will require work. theres 2 ways to do it
1) slot the crossmember and only use 1 bolt per side
2) modify the stock one making extensions for the bolt holes on the chassis, or just build a new one. they are very simple to make. 3 pieces of angle iron, some holes and some welding, done.
