TenjoTenge »
https://forums.nicoclub.com/tenjotenge-u81420.html
Fri Feb 22, 2008 9:01 am
me again ...
wires ... i connectet ....... the fuel pump relay (black pink wire)... the ecu memory... the ign relay... the ign powerand few other wires (carl H. guide) (ecept the black wire with yellow stripe/kannt find it ... got the ca harness)
i tha car i only connectet the orange wire to pin 43 of the rb20det ecu (ign start) for what reason is pin 45 ign???? ?
i checked ...... fuel pump is workin... ecu is workin (fuel pump runs at start)... starter runns
spark plugs ... there is no spark while holding the spark against the engine -.-"!!!!!!!
jeah .. there is no spark so tha engine doesnt start ... where could the problem be? ...
the engine shoult be ok, the power transistor also ... i think its the wiring inside the car ... but i dont get it ... do i have to connect all the grounds of the ecu (pin 10,20,50,60,30) ?
pls help! ..
best regards,Chris
