S13 RB20 Minimum amount of wires
Bradical123
Car: RB20 S13
Hey guys i just picked up an s13 /w RB20DET that i'm NOT planning for street use. right now i have the interior gutted and i have the wiring harness laying on my bedroom floor
What i'm wondering is what is the bare minimum amount of wires i need to run to have this engine run correctly.. i plan on running ignition, fuel pump, fans, etc from a toggle board. No A/c, heat, or anything extra. I'm looking for bare minimums here. any help is appreciated and if someone has a wiring diagram of the setup that would be awesome
THANKS!
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
A lot.
Carb it and the wiring would be stupid simple.
v kush
Car: 90 s13 coupe rb20 pushin 403rwhp
theres about 6 switches ul need to run not sure on the exact # of wires but ill get some pics up on mon if thats cool i have exactly what ur looking for its a was a drag car so theres and extra toggle for a water2air intercool
StricNyne
hahaha carb lol
Bradical123
Car: RB20 S13
Seriously a carb?! lol no thank you
and thanks kush that would be very helpful.. do you even need the harness that runs through the passenger compartment? if you run the switches it seems like all you would need is the section of the harness that runs from the ECU to the engine ... not to sure
StricNyne
hmm aqsk toad8xu he has a drag kouki he might have some insite
RustspecS13
Car: '74 260z and '88 300zx turbo
Your not really asking about the engine wiring harness, your mainly asking about the chassis harness.
You'll also need tail lights and turn signals/hazards if its a street car. The turnsignals wont work with out the hazard switch btw.
~Alex
Bradical123
Car: RB20 S13
RustspecS13 wrote:Your not really asking about the engine wiring harness, your mainly asking about the chassis harness.
~Alex
well yeah i kinda figured you would need all the wires that run to the ECU for the car to run right. can i just eliminate everything except the engine harness?. I am NOT using this for the street
v kush
well i have no harness what so ever i started from scratch but most tracks require headlight runninglights and brakelights so try not to mess with those i didnt know that when i start and had to rewire them and im ganna get those pic tomorrow gonna try an pull my dash
btw u got any interior parts??
Bradical123
Car: RB20 S13
Yeah pretty much the full interior minus a few broken panels=]
Other than the few wires for the lights, are the only wires your running the ones that go to the ECU connector?
It makes sense to me if you have a few toggles for starting, fuel pump, and fans. the only other wires you would need are for charging system (if you even use it) and the wires that the ECU needs
v kush
pm me some pics of the backseats,seatbelts i need all the brackets for em to and r ur door manual or electric?
and yea its just the ecu wires i have a starter, fuel, fan, lights, and a master electrical switch
