s13 RB 20 swap Question
vds89
Car: Nissan s13
I have a s13 91 coupe and am curious how difficult it is to install a rb20...what would need to be change, fabricated,.....etc.
nismopwr240
Car: RB20 240sx
if u are uncapable of doing a little research to find out for yourself then this swap is much too hard for you. Give up now
s13point5
Car: 89 240sx
although im not really down with harsh n00b bashing, he is right. there is LOADS of info about the swap with just a few clicks of your mouse.
Dittoz7
Car: 1997 2f0WtY SE!
foulplay
Car: 1992 S13 Fastback
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
mello88
Car: s13
vds89 wrote:I have a s13 91 coupe and am curious how difficult it is to install a rb20...what would need to be change, fabricated,.....etc.
I always wonder, how do you rate "difficulty"? Like on a scale from one to ten? LOL.. How mechanically inclined are you? Do you do all your own work and install upgrades on your car? If so then you should be fine with help from a few friends, a cherry picker and an air compressor... But you'll only survive the RB swap if you take the time to research the swap and download and study the FSM.
Usually i'd just say "Search!!" also... But looks like I'm late to the gangbang today.. To be different I'll give you an idea of some of the hurdles you'll face, maybe it's enough to scare you off - or - maybe you'll scoff at the list and push on. You can custom fabricate all of it, or buy most of these parts pre-built online: cross member, motor mounts, sway bar spacers, modify the wiring harness, splice KA lower harness, splice dash wiring, recalibrate your tach, swap speed sensor from the KA transmission, modify/replace the power steering lines, custom/modify front mount intercooler piping, custom/modify dump pipe & downpipe, maintenance on the motor (water pump, timing belt + tensioners, head gasket, intake/exhaust gaskets, oil pan de-dented, exhaust manifold studs, new rubber hoses, new belts, thermostat, crank collar), radiator, radiator pusher fans, fuel pump, FPR...... The list goes on and on. Bottom line is if you're not willing to research the swap and motor itself, you'll never be able to get it done OR running well. GL!
foulplay
ripracer wrote:
Hey this Search button doesnt work.
Carl H
i think the point has been made, thread closed.
