Gold Digger »
https://forums.nicoclub.com/gold-digger-u15335.html
Fri Mar 14, 2008 12:55 pm
Are you referring to body parts, engine parts, suspension parts?
Engine parts, as long as you have the RB26DETT bolted in, which is no easy task to get up and running, then of course.
Body parts, I think you can do it, but they don't line up very well. There is one member here on NICO that has an S13 with an R32 front. It doesn't look bad, but it doesn't look like it was ment to have those parts on it either.
Suspension, the front suspension is different, in terms of the strutts. The rear has the same bolt pattern, but the stroke on an S chassis is a little bit longer. You have to use some helper springs on the coilovers to aid in the rear if you use Skyline suspension.
