JamesT43 »
https://forums.nicoclub.com/jamest43-u4287.html
Fri Feb 21, 2003 5:49 am
As for removing Super HICAS, when I first bought my car, I wanted to get rid of it too. I autocross, and I thought that having the HICAS system might make the rear end of the car vague and hard to control. In a way, this is true, but if you learn the system it can actually help. If you plan to drift the car, however, eliminating HICAS is a must.
Sometime next week, I am going to try to splice in a switch in one of the wires that HICAS uses. When any part of the system stops working, the wheels lock straight and the HICAS light goes on.
If I get this to work right (don't know why it wouldn't) I should be able to turn the system on and off from the ****pit.
Ill experiment and write up a little how-to when I am done.
